Add a New Site
You can add a new site password entry (i.e., a set of credentials to log in to a website or app, typically containing a username or email address and password) to your LastPass vault in several ways – while logging in to a website, saving manually, or adding directly within your vault. You can store an unlimited number of password entries in your LastPass vault.
Add a password by logging in to a site
Save a password manually
Your site has now been added to your vault.
Add a password while in your vault
and select Open My Vault.
- Select Passwords in the left navigation.
- Select the Add icon
- Enter the URL of the site, and all other information you want to store. You can also select a folder to store it within. If desired, click Advanced Settings and enable the checkbox(es) for additional security options of Require master password reprompt, Autologin, and/or Disable Autofill.
- Select Save.
Clone an entry in your vault
- To clone a single item, right-click on the entry you wish to clone then select Clone.
- To clone multiple items, check the boxes for each of your item entries, then use the Action drop-down menu and select Clone.
- If desired, make changes to any of the site entry fields. If no changes are made, your site entry will be an exact copy of the original.
- Select Save.
