Add a password
You can add a new username and password while logging in to a website automatically, saving manually, or adding directly within your vault.
Add a password by logging in to a site (automatically)
Use this method if you know your login credentials, and LastPass will prompt you to add the password automatically.
Add a password manually via the LastPass browser extension
You can add a password manually using the LastPass browser extension menu.
Add a password manually by saving all entered data
Adding a site using this method is helpful for website login forms that require more than just a username and password.
Add a password using the in-field icon on a site
You can add a password inline within a site field while visiting a site.
Add a password from within your vault
Log in to your vault to add a password.
- Select Passwords in the navigation pane.
- Click the Add icon
- Enter the URL of the site, and all other information you want to store.
- If desired, do any of the following:
- Select a folder to store your password in.
- Select Advanced Settings and enable the checkbox(es) for additional security settings of Require Master Password Reprompt, Autologin, and/or AutoFill.
- Create a TOTP code so the site (which is enabled with Two-Factor Authentication) can be shared with others
Note: This feature is only available for LastPass Teams and LastPass Business accounts. What type of LastPass business account do I have?
- Click Save when finished.
Clone an entry in your vault
Duplicate an existing password entry within your vault.
- To clone a single item, right-click on the entry you wish to clone then select Clone.
- To clone multiple items, check the boxes for each of your item entries, then use the Action drop-down menu and select Clone.
- If desired, make changes to any of the site entry fields. If no changes are made, your site entry will be an exact copy of the original.
- Select Save.
Prevent the in-field icon from appearing for specific site passwords
If you do not want the gray in-field autofill LastPass icon to appear in your login fields, you can disable it within your LastPass browser extension Preferences to remove it for all sites, or add a site as a Never URL so that the icon does not appear for specific sites.
