Add a site as a Never URL
You can add a Never URL so the auto-fill icon does not appear for specific sites.
- Select the Never URLs tab.
- Click Add.
- For the Type, use the drop-down menu and select Never Show Context Icons.
- Enter the URL of your desired site, then click Add.
- Close the Account Settings window.
Results: When you navigate to your specific site, the LastPass auto-fill icon is no longer displayed.
