Add and Manage LastPass Admin Policies
Full policy list
You can view all available policies for LastPass Business on the LastPass Policy page at https://lastpass.com/policy_doc.php. Please note that you must be actively logged in with a LastPass Business account in order to view the full list of policies available.
Policy categories
These policy categories include:
- Overview – These policies are currently configured and enforced for your account by a company administrator, and includes both enabled and default policies
- Default – These policies are enabled by default for all users (but can be disabled or configured otherwise)
- Recommended – These policies are disabled by default but are recommended by LastPass to enable and configure to best suit the business needs of your organization
- Access Controls – These policies manage users' access to LastPass
- Password Rules – These policies manage requirements for site passwords and when users create or use their master password
- Account Restrictions – These policies enforce account restrictions for users
- Administration – These policies manage general administration, including notifications and reporting for admins, limitations on user access for the Admin Console, and restrictions on upgrade prompts & PasswordPing checks
- Multifactor – These policies manage all settings, restrictions, and requirements for Multifactor Authentication for users
- Other – These are all other policies that do not fall under the previous categories
Configure and enable a new policy
Edit an existing policy
- From within the Admin Console, go to in the left navigation.
- Click the Overview tab and locate your desired policy.
- Click Edit details and make your desired changes to the policy configuration.
- Click Save Changes.
Delete a policy
- Locate your desired policy by using the Search field.
- Toggle off the switch for your policy.
- When prompted to delete, click OK to confirm removal.
About policies for federated users
About policies for LastPass Business accounts
- The Require use of LastPass MFA policy can be enabled to require users to set up and use the LastPass Authenticator when accessing their LastPass vault. This requires an account with LastPass Business + Advanced MFA add-on.
- The Override default MFA methods allows to override the default MFA authentication methods. The default primary authentication method is "push", and the backup authentication method is "text/call". Use the Value field to offer different methods for users during setup. Enter the following numbers separated by commas:
- 1 - Push notifications via LastPass Authenticator
2 - Codes via TOTP compatible authenticator app (such as Google, Microsoft, Okta, etc.)
- 3 - Text/Call
- 4 - YubiKey OTP
For example, enter the value 1,3,4 to show users these three options during MFA setup:- 1 - Push notification via LastPass Authenticator
3 - Text/Call
4 - YubiKey OTP
In this example any method not chosen as primary can be chosen as a backup in case the primary is unavailable.
- The Hide Cloud Apps from end users policy can be enabled to hide the Cloud Apps vault menu item (used for integrated SSO) from appearing in the left navigation of users' LastPass vaults (if the admin has already implemented their own single sign-on solution or does not need to use LastPass integrated SSO).
