Cisco ASA VPN configuration for the LastPass Universal Proxy LDAP protocol
Before you begin:
Set your local user profile to have the proper privilege level to your Cisco ASA system:
- In the Note: You must set your privilege level to 15 in order to have unrestricted administrator access to your ADSM/CLI management surface.
menu, Privilege Level field, select 15.
