As a LastPass admin, you can set up preferred authentication methods, enforce the required use of the LastPass Authenticator app when accessing SSO apps, enable or disable offline mode when using the LastPass Authenticator app and/or geofencing, set up account recovery options, and much more.
Restriction: This feature might not be available for your account as this is a legacy feature.
About this task: Admins have the option to turn off an authentication method or enable multiple methods and allow users to choose their primary authentication method.
- Select MFA or SSO & MFA in the left navigation.
- Go to in the left navigation.
- To set up account-wide default authentication methods and/or feature settings (listed below), you can configure the settings directly on the Authentication and Recovery policy page, which automatically assign the default policy to all users and groups in your organization.
- To create a custom authentication methods and/or feature settings for specific users and groups, do the following:
- Select .
- Create a policy name, then configure the policy with your desired settings (listed below).
- Click Save.
- Select your desired users and/or groups to assign, then click Save.
- Next, set your default or custom policy by configuring any of the following options:
- iOS or Android Authorized Authentication Methods – Enable or disable preferred biometric authentication options (fingerprint, face recognition, pattern), and/or allow users to change the order in which they are presented. To automatically set the same policies for both iOS and Android, check the box in the upper-right navigation for The same as iOS policies setting.
Note: Authorized authentication methods can be different based on users' devices (iOS and Android).
Note: This is an account-wide policy setting and is not available to configure for custom policies.
Result: You have now created account-wide or custom policies and assigned to the appropriate users and groups.
