Can users log into SAML applications with credentials other than email?
Yes, admins can change the login identifier under the app's settings. Expand the Advanced Setup tab, change the Identifier from Email to another attribute.
- Click Admin Console.
- Click MFA or SSO & MFA in the left navigation.
- Go to .
- Open the app setup window, expand the Advanced Setup tab, change the Identifier from Email to the new attribute.
- Click Save.
