Change language on the homepage
You can change the default language for LastPass on the homepage.
- Go to https://www.lastpass.com.
- Scroll to the bottom of the homepage, then click the Language icon
and select your desired language from the menu.
Results: The LastPass homepage now displays in your newly selected language.
