Using the in-field active LastPass icon  |
- In the login field of your site, click the active LastPass Field icon
- Hover over the entry you want to update, then select the Edit icon
- Make your desired changes. To reveal text as you type, click the Show Text icon
. You can also click the History icon to view the username and/or password history for this stored site.
- When finished, click Save.
Using the LastPass browser extension (new experience) |
- Click the active LastPass icon
- Navigate to the site password in the extension menu, then select
and Edit item.
. You can also click the History icon to view the username and/or password history for this stored site entry.
Using the LastPass browser extension (previous experience) |
, then do one of the following:
- Hover over your desired entry from the list of matching sites at the top of the web browser extension menu and select the Edit icon
- Look up your stored site using the Search field and select the Edit icon
Within your vault |
- Select Passwords in the left navigation.
- Locate your site entry, then hover over it and click the Edit icon
