Checklist for configuring Cisco ASA VPN
Check the following settings:
- The Login DN field value must be the same as the Active Directory's distinguishedName field value.
- The Server Name or IP Address field value must be the same as the Universal Proxy's IP address. For example, 172.19.0.8 in this test case.
- The Base DN field name must the same as the Active Directory's base domain name.
