Cisco ASA VPN configuration for the LastPass Universal Proxy RADIUS protocol
Before you begin:
Set your local user profile to have the proper privilege level to your Cisco ASA system:
- In the Note: You must set your privilege level to 15 in order to have unrestricted administrator access to your ADSM/CLI management surface.
menu, Privilege Level field, select 15.
About this task:
Note: Only Password Authentication Protocol (PAP) and Challenge Handshake Authentication Protocol (CHAP) modes are supported by the service.
