Configuring the LastPass Active Directory Connector
Once installed, configure the settings for the LastPass AD Connector.
Connection
Configure the connection between LastPass and your Active Directory.
Configure the Connection settings.
Actions
Configure your Actions settings to specify what actions should be performed when specific events happen to users in your Active Directory.
Configure the "When a user in Active Directory is detected" setting.
Configure the "When a user in Active Directory is deleted" setting.
Configure the "When a user in Active Directory is disabled" setting.
Configure the "When a user in Active Directory is removed from group in filter" setting.
Sync
Configure your Sync settings to specify your fields, groups, and users that you would like to sync between LastPass and your Active Directory.
Configure your Sync settings.
Configure "User memberships" settings.
Debug
Configure your Debug settings for troubleshooting AD Connector syncing issues.
When finished, click Finish, then go to Home and check the box for Enable sync to begin syncing.
Migration
If you have set up Active Directory Federation Services (AD FS) in your LastPass Business account, the Federation option in the LastPass AD Connector can be used to convert non-federated users to federated user accounts. For detailed instructions, see How do I convert an existing LastPass user to a federated (AD FS) user?
