We are currently experiencing an unplanned outage for this product. View Service Status
LogMeIn support sites no longer support Microsoft's Internet Explorer (IE) browser. Please use a supported browser to ensure all features perform as they should (Chrome / FireFox / Edge).
For information on the recent security incident, visit our blog.
Select the Edit icon to the right of your desired multifactor option.
For the Enabled option, use the drop-down menu to select Yes.
For the Permit Offline Access option, use the drop-down menu to select Disallow, which requires the use of multifactor authentication and to be connected to the Internet when using LastPass.
Configure all other required fields for your authenticator (if applicable), then click Update when finished.
Enter your master password, then click Continue.
If you have already set up multifactor authentication for this authenticator, you are done. If you have not, follow the steps to enroll your device. Instructions will vary depending on the authenticator app you have selected.
