Does LastPass Workstation Login work even if I am offline?
Yes. Workstation Login (as well as the LastPass Authenticator) support Offline Mode, which enables employees to securely log in even if they are traveling or do not have an internet connection. Instead of using face recognition or fingerprint identification, users will authenticate with a One Time Password (OTP) generated by the LastPass Authenticator.
