Use Duo Security Authentication
Duo Security is a secure, multifactor authentication application that can be used as an added layer of security to protect your LastPass account.
To get started, LastPass admins must complete the steps for enabling Multifactor Authentication in the Admin Console.
Using multiple multifactor authentication options
