How do I manage my Equivalent Domains in Account Settings?
If you access multiple websites from a single provider, adding these sites as equivalent domains allows you to use just one username and password.
Keep in mind:
- Both domains and subdomains can be entered by a LastPass user (e.g., sample.com and services.sample.com, respectively)
- All subdomains and paths are considered equivalent automatically by default (e.g., services.sample.com where "services" is the subdomain)
- To mark subdomains as having the same login credentials in LastPass, specific syntax is required. You must enter "=" directly before the subdomain, then enter a space after the domain, then enter a comma, then enter another space (e.g., =services.sample.com , login.lastpass.com)
- Top-level domains (TLDs) are not accepted and will be considered as invalid (e.g., *.com)
Equivalent domains labeled as "Global" are domains that are set by LastPass, and can be edited and/or removed altogether. Equivalent domains added by you will be labeled as "Local" and can also be edited and/or removed.
Add a new equivalent domain
To mark domains as having the same login credentials in LastPass, do the following:
Edit an existing equivalent domain
If at least one of the domains that you wish to make equivalent is already listed, do the following to edit the existing entry:
Delete a set of domains
- Once in your vault, select Account Settings in the navigation pane.
- Select the Equivalent Domains tab.
- Select the Delete Entry icon
next to the domain entry that you want to delete.
- When prompted, click OK to confirm.
You have deleted your selected domain(s).
