Edit existing users and settings for passwordless login access policies
    You can edit existing users and settings for passwordless login access policies in the new Admin Console.
    Restriction: This feature might not be available for your account as this is a legacy feature.
    3. Go to Policies > Passwordless > Access policies.
    4. For your desired policy, change either of the following:
      Policy options Instructions
      Assigned users
      1. Select the Assign Users icon .
      2. Select or remove your desired users/groups.
      3. Select Save.
      Settings
      1. Select the Settings icon .
      2. Make your desired changes.
      3. Select Save.
    5. Select Save when finished.
    Results: You have updated your selected passwordless login access policy.
