How do I manage my Multifactor Options in Account Settings?
Multifactor authentication is an added layer of security that you can enable within LastPass, and requires a second step before you can gain access to your account. Enabling this security feature helps protect your account from keyloggers and other threats, even if your master password was compromised, your account could not be accessed without this second form of authentication.
Alternatively, you can disable multifactor authentication in your Account Settings.
Are you a LastPass admin for a LastPass Teams or LastPass Business account? It is recommended that you complete the steps for enabling multifactor authentication in the Admin Console.
Enabling a multifactor authentication option to access LastPass
Enabling more than one multifactor authentication option
You can enable more than one multifactor authentication option to be used when accessing your LastPass vault. It is recommended whenever possible to enable multiple authentication options (even on multiple devices) in case you ever lose access to one device, you will have a backup.
Once you have enabled your first Multifactor Option, you can repeat the same steps in Enabling a multifactor authentication option to access LastPass to enable as many alternative multifactor options as needed.
