Enable offline access for your account
    Enable offline access for your LastPass account so you can still access your vault even without an the presence of an Internet connection.
    3. Select the Multifactor Options tab.
    4. Select the Edit icon Edit option for your desired multifactor option.
    5. For the "Enabled" option, use the drop-down menu to select Yes.
    6. For the "Permit Offline Access" option, use the drop-down menu to select Allow. This will store an encrypted vault locally so you can log in without using multifactor authentication in case of a connectivity issue.
    7. Configure all other required fields for your authenticator (if applicable), then select Update when finished.
    8. Enter your master password, then select Continue.
      Troubleshooting: If you have not already set up multifactor authentication for your selected multifactor option, follow the steps to enroll your device. Instructions will vary depending on the authenticator option you selected.
    Results: You have enabled offline access for your selected multifactor option, and will be able to access your LastPass vault while you are offline.
