LastPass Admin Management of Master Passwords
You can view and manage your users' master passwords from the Admin Console. For additional security measures, you can also choose to enforce various policies for your users to adhere to when managing their master password.
If you have detected a need for a user to change their password immediately, it is recommended that you first require a password change, then destroy their active session. This will log them out of their existing session, then force them to change their password upon their next login.
View the change log
- Use the menu in the left navigation to go to Advanced Options > Business Options > Master Passwords.
Here you can view the list of users that last changed their master password, and when the last change occurred.
Require a master password change
If you need to force users to change their password upon their next login, do the following:
- Check the box in the "Action" column for a single user, or check the first "Action" box to select all users in the list.
- Click Require Password Change.
- Click OK to confirm.
Your selected user(s) now require a master password change upon their next login.
Destroy all sessions
If you need to force users to log out of their existing LastPass Business session immediately, do the following:
- Click Destroy All Sessions.
All active sessions for the user have been terminated.
