G Suite App Integration
    Set up a G Suite app integration so that your users can sign into this app using the same credentials that they use for LastPass.
    About this task:
      Name in LastPass Value
      Entity ID
      https://identity.lastpass.com
      SSO Endpoint
      Logout URL
      Certificate (PEM)
    Part 2 - Configure the app in Google Admin
    About this task: For detailed instructions, please see Google Workspace documentation.
    1. Log in to your Google admin console.
    2. Select Show more in the left navigation bar, then select Security > Authentication > SSO with third party IdP.
      G Suite Admin Security
    3. Expand the Third-party SSO profile for your organization panel.
    4. Enable Set up SSO with third-party provider.
    5. Enter the following information:
      Name Description Value
      Sign-in page URL SSO endpoint value (copied from the LastPass Admin Console)
      Sign-out page URL Logout URL (copied from the LastPass Admin Console)
      Verification certificate LastPass Certificate file you dowloaded in Part 1 Upload the LastPass Certificate you downloaded in Part 1
      Change password URL SSO endpoint value (copied from the LastPass Admin Console)
    6. If you want to use a domain-specific issuer, enable the Use a domain specific issuer checkbox.
    7. Select Save.
      Set up SSO settings in Google Admin Security settings
    Part 3 - Finalize the G Suite SSO app configuration in LastPass
    3. For the ACS field, paste the following URL:
      https://www.google.com/a/<yourworkdomain.com>/acs
    4. Optional: Enable Step-up authentication if you want to require users to confirm their identity using the LastPass Authenticator app upon each login to this SSO app.
    5. Select Advanced settings.
    6. Select one of the following options:
      • If you enabled a domain-specific issuer in Part 2, for the Entity ID field, enter google.com/a/<your_domain>.com.
      • If you did not enable a domain-specific issuer in Part 2, for the Entity ID field, enter google.com.
    7. Optional: If desired, in the Advanced settings section, add any of the following additional customizations:
      • Email (default)
      • Secondary Email
      • User ID
      • Groups
      • Roles
      • Custom
      • Sign assertion
      • Encrypt assertion
      • Sign request
      • Sign response
      • Email
      • Secondary Email
      • User ID
      • Groups
      • Roles
    8. Click Save & assign users > Users, groups & roles to begin making your selections.
    9. Search for and select your desired users, groups, and/or roles, then click Assign.
    10. Click Save & continue > Finish.
