We are currently experiencing an unplanned outage for this product. View Service Status
LogMeIn support sites no longer support Microsoft's Internet Explorer (IE) browser. Please use a supported browser to ensure all features perform as they should (Chrome / FireFox / Edge).
LastPass에 흥미로운 한 해가 기다리고 있습니다! <a href="https://support.logmeininc.com/ko/lastpass/help/lastpass-announcement-faqs" target="_blank">향후 계획을 알아보십시오.</a>
Type your question here, or browse topics below to view answers or reach a support agent.
Generate Secure Passwords
Create the most secure and random passwords by using our built-in password generator for a site, then store those sites in your LastPass vault. It is recommended to use generated passwords as much as possible as a security best practice.
Generate a secure password by doing the following:
Click the inactive (grey or black) LastPass icon in your web browser toolbar.
Enter your email address and master password, then click Log In.
Result: An active LastPass icon is displayed and you are now logged in.
Navigate to a website for which you'd like to generate a new secure password. Or, if you want to change the password for a site with one that is generated by LastPass, log in to your desired site and access your account's login settings.
Generate a secure password by doing any of the following:
Feature in LastPass
Instructions
Using the in-field icon
Click the in-field active LastPass icon .
Click the Generate Password icon .
Using the web browser extension
Click the LastPass icon .
Click Generate Secure Password.
From within your vault
Click the LastPass icon and select Open My Vault.
Go to Advanced Options > Generate Secure Password.
If desired, you can customize your password settings, which will create a new password based on your selections. Select Customize (if using the in-field icon), otherwise you can choose from the following options:
Slide the marker to select your desired Password length (or type a number in the text field) – up to 100 characters max
Easy to say – Does not include numbers or special characters
Easy to read – Does not include ambiguous characters (I vs. l, O vs. 0)
All characters – Includes any type of character
Additionally, you can:
Copy to copy the new password to your clipboard
Generate New to create a new secure password
Show History to see previously generated passwords
Once your selections have been made, select the password you generated (or Copy Password, if you are generating from within your vault).
When prompted in the upper-right navigation, click Add (to add a new set of credentials) or Update (to update an existing set of credentials) with your newly generated secure password.
Once added, it is recommended that you log out and log back in with the newly generated secure password.
