Use Grid Multifactor Authentication
    Grid multifactor authentication is an option for those who do not want to utilize mobile devices. With Grid multifactor authentication, you will print a sheet that is used to look up specific matching values when logging in to LastPass, and provide a code derived from your grid to log in and access your account when prompted by LastPass.
    For LastPass admins, it is recommended that you complete the steps for enabling multifactor authentication in the Admin Console.
    Attention: Multifactor authentication via Grid is not supported when using a mobile device. This multifactor option can only be used when accessing LastPass from a desktop web browser.
    Using multiple multifactor authentication options
