HappyFox App Integration
    About this task:
      Name in LastPass Value
      Entity ID
      https://identity.lastpass.com
      SSO Endpoint
      Logout URL
      Certificate (PEM)
    Part 2 - App Configuration
    1. Open a new tab on your browser and log into your HappyFox administrator account using the following hyperlink: https://<yourworkdomain>.happyfox.com/staff/welcome/
      1st login to happyfox
    2. Go to Manage > Integrations.
      2nd select manage-integrations happyfox
    3. Scroll down to find SAML and click on the configure link.
      3rd click configure saml happyfox
    4. Under Basic SAML Settings, for the SAML Integration active use the drop-down menu and select Yes.
    5. Click Save Settings.
      4th config basic saml happyfox
    6. Enter the information as follows:
      1. Choose SSO Provider: Custom SAML Method
      2. SSO Target URL: SSO Endpoint copied from LastPass Admin Console
      3. IdP Signature: Paste the certificate fingerprint you downloaded in Part 1
      4. Authenticate helpdesk staff using SAML: YES
    7. Click Save Settings.
    Part 3 - Finalize the HappyFox SSO App Configuration
    3. Under Service Provider, paste the following URL in the ACS field: https://yourworkdomain.happyfox.com/staff/saml/callback
    4. Select Advanced settings.
      • Email (default)
      • Secondary Email
      • User ID
      • Groups
      • Roles
      • Custom
      • Sign assertion
      • Encrypt assertion
      • Sign request
      • Sign response
      • Email
      • Secondary Email
      • User ID
      • Groups
      • Roles
