About passwordless login activation for SSO apps and workstations
    Get started as a user with passwordless login activation for SSO apps and/or workstations; steps will vary depending on whether you have received your activation email.
    Fastpath: Are you trying to set up passwordless login for your vault? No activation needed! View these instructions instead.
    Notice: Passwordless login for SSO apps and workstations requires an account with the LastPass Business + Advanced MFA add-on, whereas passwordless login for your vault is available for all account types and does not require activation.
    Passwordless login activation email status Instructions
    I have received my activation email Follow the steps in How do I activate passwordless login for SSO apps and workstations?
    I have not received my activation email Follow the steps in I can't find my activation email for passwordless login, what should I do?
    I have already completed the activation steps
    You can use passwordless login via the LastPass Authenticator in any of the following ways:
    Attention: If you want to use passwordless login to access your vault, view How do I enable passwordless login for my vault?
