Add a group manually in the new Admin Console
Manually create groups in the new Admin Console.
Note: Are you seeing something different? See these instructions for the Password Manager Admin Console or the SSO & MFA Admin Console.
- Go to .
- Enter a name for the group.
- To add users later, click Save & Exit. Otherwise, do the following:
- Select Save & Assign Users.
- Select users for the group and click Assign Users.
Results: You have created a group and assigned your selected users.
