How do I add a missing password in my vault?
If you checked your Security Dashboard and your security score indicated you have passwords that are missing, you can update your site entries by adding secure passwords to each.
Add passwords via the Security Dashboard as follows:
A new password has been added to the site password entry within your vault.
Add from the Edit Password screen
You have added a secure password to the entry where it was missing.
