Add another device for passwordless login
Once you have enabled passwordless login for your vault and added your first device, you can enable more passwordless login devices by logging in to LastPass from those devices.
Attention: Using passwordless login for your vault requires LastPass browser extension version 4.96 or later.
About this task: If
passwordless login is enabled from your vault and you log in to LastPass from a new device, you will be prompted to enter your
master password then authenticate using the
LastPass Authenticator app in order to add it as a new
passwordless login device.
Results: You have enabled
passwordless login for your vault from this specific device.
What to do next: You can
log in to your LastPass vault using passwordless login from this device
