How do I add SSO apps for LastPass users?
App integrations (that is, SSO applications) are common online tools used within your company for which a LastPass admin has set up a single sign-on integration. This allows you to sign in to those apps using the same credentials that you use for LastPass.
Terminology
- SSO apps
- Apps are the site entries stored in a LastPass user's vault and accessed by that user for which a LastPass admin has set up single sign-on.
- You can sign in to your SSO app and launch any of your web applications without re-entering your credentials.
Add the SSO app to LastPass
Configure the app
Sign in to your account at the app's website and go to this app’s settings to enable single sign-on. Make sure your app recognizes LastPass as the Identity Provider. Some apps allow you to upload settings in an XML file, while others require you to copy and paste the following information:
Name in LastPass | Value |
Entity ID | |
SSO Endpoint | |
Logout URL | |
Certificate fingerprint | Provided in the Set up app section of the SSO app. If needed, download the LastPass certificate in PEM, DER, or Download metadata (XML) format. |
Certificate fingerprint (SHA256) | |
Certificate (PEM) |
Set up LastPass
Assign test users to your app
During the app setup, you can click
Save & assign users to assign a test user to your app.
Assign users to your app
To assign users, groups, and/or roles to your SSO app, do the following:
