You can re-order the accounts you have registered in the LastPass Authenticator app.
Before you begin: Install the
LastPass Authenticator on your mobile device for either
iOS (running iOS 10 or later) or
Android (running Android OS 4.0.3 (Ice Cream Sandwich) or later).
- Open the LastPass Authenticator app on your mobile device.
- Select
in the top toolbar.
- Sort or arrange by any of the following:
- Issuer (A-Z)
- Issuer (Z-A)
- Newest first
- Oldest first
- Select Custom order then tap & hold
next to your desired account and drag it up or down to re-order.
Tip: You can make an account a Favorite by moving it under the Favorites folder.
- Select Done when finished.
