How do I view at-risk passwords in my LastPass vault?
LastPass helps you easily identify site passwords that are considered at-risk in your vault, then guides you through the process of changing those unsafe passwords on both the affected site and within your vault using our built-in secure password generator.
A password is considered "at-risk" if it is weak, reused, or missing for the site entry in your vault.
You can view these passwords that need attention from within your vault on the Passwords page, or from the Password Security page via the Security Dashboard.
View from the Passwords page
View from the Password Security page
