How do I change weak or reused passwords in my vault?
If your security score in your Security Dashboard indicated that you have weak and/or reused passwords in your vault, you can change these at-risk passwords individually to improve your overall security score.
Tip: To prevent storing weak and/or reused passwords in the future, you can use the built-in secure password generator for each site password you add to your vault as a best practice for good password hygiene.
Note: This feature is not available for LastPass Free users. Learn how to upgrade to LastPass Premium, or view LastPass plans and pricing for feature information.
Note: LastPass uses the industry-standard zxcvbn library to assist in calculating each password's strength. As a result, your individual passwords' strength and your security score for all of your passwords in your vault may vary. Individual password strengths can be 0-25-50-75-100 percent (or a different value if the individual password is reused on multiple site password entries) while the security score can be anywhere between 0-100. Learn more about password strength and security score calculation.
Change from the Password Security page
You can change your weak or reused password from the Password Security page by accessing from the LastPass browser extension notification or directly via the Security Dashboard within your vault.
Results: Your password has been updated on both the website and within your vault, and is now displayed as "Secure" on the
Password Security page.
Change from the Edit Password screen
