How do I clear my temporary one-time passwords for LastPass?
You can clear the temporary one-time passwords you generated if you are concerned they have become compromised, or if you no longer need to use them.
If you are concerned that your LastPass account has been compromised, follow these steps.
If you are concerned that someone may have gotten access to your one-time passwords, you can invalidate them by doing the following:
and select Open My Vault.
- Select Advanced Options in the left navigation.
- Select Manage one-time passwords.
- Enter your master password, then click OK.
- Click Clear all OTPs.
- If prompted, enter your master password, then click OK.
You have cleared all of your one-time passwords.
