The recipient of a shared item cannot edit the shared item. If the recipient wants to make changes to a shared item, they must clone the item (creates a separate item entry) and make the changes locally within their vault.
About this task:
Cloning an item can only be done from within your online vault, as follows:
- Select Sharing Center in the left navigation.
- Select the Shared with Me tab.
- Click Accept for the shared item.
- Locate the item in your vault.
- Right-click on the entry you wish to clone, then select Clone.
Note: You cannot clone multiple items.
- If desired, you can make changes to the site password or secure note entry, otherwise if no changes are made the entry will be an exact copy of the original.
- Click Save.
Results: You can now make changes locally to your cloned shared item.
