Configure LastPass Universal Proxy v4.x with the server.properties configuration file on Linux without using the CLI tool
    After you have installed LastPass Universal Proxy for the first time, it must be configured before use. You can configure LastPass Universal Proxy using either the CLI tool or editing the server.properties configuration file in a text editor. In the following we provide a step-by-step guide on how to do the configuration with the server.properties file.
    Before you begin: Check Set up LastPass Universal Proxy v4.x on Linux for information on downloading and installing LastPass Universal Proxy on Linux.
    About this task:
    Note:
    We recommend using the CLI tool when configuring Universal Proxy for the first time, as it generates an initial version of the server.properties file. This file is human-readable. Therefore, for further configurations you can edit the server.properties configuration file with any of your text editors.
    Also, if you made a mistake when editing the configuration file, you can always start fresh from the CLI tool, and create a new one.
    For more information on the configuration settings, see Configure LastPass Universal Proxy v4.x on Linux using command line interface (CLI).
    1. Go to the /usr/local/universalproxy/conf folder, and save server_template.properties as server.properties.
    2. Open the server.properties file with a text editor and edit the properties.
    3. Save the server.properties file.
      The server-template.properties file in /usr/local/universalproxy/conf contains all the possible attributes and their descriptions.
      ### This configuration file contains the settings for the Universal Proxy.
      ### It has four sections
      ### 	* Server settings
      ### 	* LastPass API settings
      ### 	* LDAP settings
      ### 	* RADIUS settings
      ### Fill Server settings and LastPass API settings first. Then fill LDAP settings if you plan to use
      ### Universal Proxy using LDAP or LDAPS or fill RADIUS settings if you are going to use RADIUS.
      ### If a value is not applicable for your case leave it as it is.
      ### For further information see the online documentation:
      ### 	https://support.lastpass.com/help/what-is-lastpass-universal-proxy
      ### Note, that it is also possible to configure Universal Proxy using the command line tool.
      ### Issue the following command in the CLI to start the command line configuration tool:
      ### 	sudo uproxy -configurationTool
      ### Online documentation for the configuration tool:
      ### 	https://support.lastpass.com/help/how-do-i-configure-the-lastpass-universal-proxy-via-command-line-on-linux
      ### Universal Proxy Server settings ###
      ## Server settings: set these values to configure how the Universal Proxy handles incoming authentication
      ## requests. Choose the authentication protocol (LDAP, LDAPS or RADIUS), specify the ports and domains and
      ## set the server mode (LP, PLP, SFA).
      ## For an explanation about server modes see the documentation:
      ## 	https://support.lastpass.com/help/what-is-lastpass-universal-proxy#server_modes
      # The protocol to authenticate users. [LDAP | LDAPS | RADIUS]
      server.protocol=
      # The mode in which Universal Proxy should run [LP | PLP | SFA].
      server.mode=
      # The port on which Universal Proxy listens on.
      server.port=
      #Accounting port is used if Radius protocol is selected.
      #The accounting port Universal Proxy listens on.
      server.accounting.port=
      # The name of your company. This value appears to end users in the MFA app.
      company.name=
      company.name=
      ### Authentication server settings: Common Login Service      ###
      cli.cls.integration.key=
      cli.cls.integration.secret=
      default.cls.auth.method=
      ### Authentication server settings: LDAP server ###
      ## LDAP settings: set these values to configure Universal Proxy to be able to communicate with a LDAP server.
      ## Leave these values blank if you are not planning to use Universal Proxy for LDAP authentication.
      ## The ldap.admin.password field is applicable only if the server mode is LP.
      ## The ldap.address, ldap.port and ldap.tls fields can only be used if the server mode is either PLP or SFA.
      ## For the current server mode see the value of the server.mode variable in this file.
      ## Leave any value blank which is not applicable for your current setup.
      # The address of the OpenLDAP. Applies to server modes: [PLP | SFA]
      ldap.address=
      # The default LDAP server type: [auto | ms | openldap]
      default.ldap.server.type=
      # The port on which the OpenLDAP expects authentication messages (default: LDAP: 389, LDAPS: 636). Applies to server modes: [PLP | SFA]
      ldap.port=
      # The distinguished name of the LDAP admin user. Example: CN=admin,CN=Users,DC=domain,DC=com
      ldap.admin=
      # The password of the LDAP admin user. Applies to server modes: [LP] only.
      ldap.admin.password=
      # LDAP naming attribute: the name of the LDAP field in which the Linux user logon name is stored. Possible values: uid
      ldap.attribute.login=uid
      # Password of the Keystore and Truststore files containing the SSL certificates. Applies only if you chose LDAPS protocol in Universal Proxy Server settings.
      keystore.password=
      ### Authentication server settings: Radius server ###
      ## RADIUS settings: set these values to configure Universal Proxy to be able to communicate with a real RADIUS server.
      ## Leave these values blank if you are not planning to use Universal Proxy for RADIUS authentication.
      ## Note, that radius.server.address and radius.server.port are values which have to be filled only if the
      ## server mode is either PLP or SFA.
      # The address of the RADIUS server. Applies to server modes: [PLP | SFA]
      radius.server.address=
      # The port on which the RADIUS server expects the authentication messages (1812 by default). Applies to server modes: [PLP | SFA]
      # radius.server.port=1812
      radius.server.port=
      # The accounting port of the Radius server.
      # radius.server.accounting.port=1813
      # The RADIUS secret.
      radius.secret=
      #RADIUS Ldap authentication
      radius.ldap.auth.enabled=
