Create vault identities to act as mini-vaults to group similar site passwords, notes, and items.
- In the lower-right corner, click the Add icon
- Enter a name for the new identity.
- Optional: If desired, check the box for the Require Master Password Reprompt setting.
- Drag and drop items from the "Available Items" (center) column to the "Selected Items" (right) column to include in the new identity.
Tip: You can add the same items into more than one identity.
- Click Save.
Results: You have created a new vault identity containing your selected items.
