How do I delete an existing SAML integration?
You can view your existing SAML integrations established in the LastPass legacy (old) Admin Console, and delete any SAML service that is no longer needed.
Important: If you are no longer using a SAML integration, it is highly recommended that you delete it.
Note: Are you seeing something different? View these instructions for using the new Admin Console instead.
About this task: To delete your existing SAML integration in the legacy (old) Admin Console, do the following:
Results: You have deleted your selected SAML service from LastPass and deleted the SAML key from the associated SSO app's Service Provider settings.
