How do I disable autofill for sites?
    You can disable autofill for specific sites for which you have stored login information but do not want LastPass to automatically fill it in for you. This setting can be managed for individual sites, or for all sites in your web browser extension preferences.
    Tip:
    Enabling autofill increases the risk of exposing a site's password if that site ever becomes compromised.
    Disable autofill per site
    1. Click the active LastPass icon in your toolbar.
    2. Use the Search field or go to All items > Passwords and locate your desired site.
    3. Click the Edit icon to open the site entry.
    4. Under the Advanced Settings section, check the box to enable the Disable AutoFill option.
    5. Click Save.
      Edit password
    You have disabled autofill for your specific site.
    If the site is launched from the LastPass vault or from the LastPass browser extension, it will still automatically fill and log you into the site, even if your site Preferences are set with "Autologin" disabled and "Disable Autofill" enabled.
    Disable autofill for all sites
    2. Select Account Options OR < your username > at the bottom of the menu.
    3. Select Extension Preferences.
    4. Click the General tab.
    5. Under General, uncheck the box for the Automatically Fill Login Information option.
    6. Click Save.
    You have disabled autofill for all sites.
