How do I disable email verification for LastPass?
If LastPass detects a login attempt from an unidentified location (from any new computer, mobile device, or new IP address), the system will want to verify that it's really you logging in to access your LastPass vault by sending a verification email to the LastPass account email address (or security email, if added) that contains a link you can click on to verify that it's you.
Tip: If you choose to disable email verification (not recommended), it is highly recommended that you enable multifactor authentication to protect your LastPass account as a security best practice.
- Select Show Advanced Settings.
- For the "Disable Email Verification" option, check the box to enable the Don't require email verification from unknown devices and locations setting.
- Select Update.
- When prompted, enter your master password, then select OK.
Results: You have disabled email verification for your LastPass account.
