How do I disable multifactor authentication for users in LastPass Business?
If there are multifactor authentication options are already enabled for your company account – with policies enforced to require use of those options – and now you want to disable multifactor authentication for some or all of your users, you must complete the steps below to ensure a seamless experience for your users.
Disable for all users
You can disable multifactor authentication for all users, company-wide.
- Log in to the Admin Console.
- Log in and access the LastPass Admin Console by doing either of the following:
in your web browser toolbar, then select Admin Console in the menu.
- Log in at https://lastpass.com/company/#!/dashboard with your admin email address and master password.
- Disable policies that require use of multifactor authentication.
- Go to
- Toggle off all switches that require use of specific or any multifactor authentication options.
- Disable all multifactor authentication options.
- Go to .
- Toggle off all the switches for all multifactor authentication options.
- Disable multifactor authentication for all users.
- Check the box next to Email in the user table header row to select all users.
- Select .
- When prompted, click OK to confirm.
You have now disabled use of multifactor authentication for all users within your company account.
Disable for selected users
Select your desired users for which to disable multifactor authentication.
- Disable policies that require use of multifactor authentication for your selected users.
- Disable multifactor authentication for users who have it enabled already.
You have now disabled use of multifactor authentication for your selected users.
