How do I disable offline access for multifactor authentication for LastPass?
    You can disable access to your LastPass vault when you do not have an internet connection.
    3. Select the Multifactor Options tab.
    4. Locate your enabled multifactor authentication option, then select the Edit icon .
    5. For the "Permit Offline Access" field, use the drop-down menu and select Disallow.
    6. Select Update when finished.
    7. Enter your master password and select Continue.
    8. Click OK to confirm.
    Results: You have disabled offline access and will no longer be able to access your LastPass vault when you have little to no internet connectivity.
