How do I disable password alerts for at-risk passwords?
    You can turn off "password at-risk" alerts displayed in your vault or in your browser extension.
      • In your web browser toolbar, click the LastPass icon active LastPass icon and select Open My Vault.
    3. Click the General tab, then select Show Advanced Settings.
    4. Select Disable Password Alerts.
    5. Select Update, then re-enter your LastPass master password to confirm the update.
    Results: Your "password-at-risk" alerts are disabled in your vault and in the browser extension.
