Download and configure the Workstation MFA installer for Mac
As a LastPass admin, get the integration key and integration secret, then download the Workstation MFA installer for Mac and configure it with your designated integration key and integration secret.
Add the Workstation MFA app for Mac.
Save the integration key and integration secret.
Download the LastPass Workstation MFA installer.
Configure the installer package.
Run the installer package.
Results: You have configured the
Workstation MFA installer for Mac.
What to do next: Once configured, you can distribute the installer package using your organization's preferred deployment methods.
Note: Instructions will vary, depending on your preferred distribution method.
PLEASE READ BEFORE PROCEEDING!
Warning: Be sure all your desired users have enrolled the LastPass Authenticator app with their LastPass account before Workstation MFA is installed on their machine – failure to do so will result in the user being locked out of their workstation and unable to log in.
