How do I enable and use LastPass for autofill via the iOS Safari extension?
You can enable LastPass as your chosen autofill option in the Safari mobile browser extension, which is one of two available autofill integrations available for LastPass on iOS. This integration gives you the full desktop experience of LastPass all from the Safari mobile browser, allowing you to automatically fill login credentials and form fill data directly into websites launched in the Safari browser, as well as offer the ability to save credentials, generate secure passwords, edit vault items, and much more.
Enable LastPass for autofill in Safari extension
First, enable LastPass to be used for autofill in the Safari mobile browser extension.
- iOS device running iOS 15 or later
- LastPass app for iOS app installed and running v5.12.0 or later
- Log in to the LastPass app for iOS.
- Enable LastPass in the iOS Safari extension.
- Allow permissions for LastPass to save and autofill.
Use LastPass for autofill in Safari extension
Once enabled, you can use LastPass to automatically fill login credentials and form fill items in Safari.
