Enable and use passwordless login for vault on mobile
You can set up passwordless login for vault on your mobile device, which allows you to log in your LastPass vault via the LastPass app for iOS or Android using your device's stored biometrics (face or fingerprint) instead of manually entering your master password.
Restriction: LastPass Business accounts that have enabled federated login with a third-party identity provider cannot simultaneously enable passwordless login for the vault.
Requirements
Before you begin: You must have the following:
- An active LastPass account (any plan, including Free)
Notice: If you are part of a LastPass Teams or LastPass Business account, your LastPass admin must enable this feature via the "Enable biometric login on mobile app" policy.
- A mobile device that meets the requirements listed in the table below
iOS | Android |
How to enable
To get started, enable passwordless login for vault on your mobile device.
Log in to the LastPass app.
Enable passwordless login.
Results: The
Log in with <biometric option> setting is now enabled, and you have enabled
passwordless login for vault on mobile via biometrics (face or fingerprint) from this specific device.
What to do next: Log out of the
LastPass app (go to
) to try out
passwordless login.
How to use
Once enabled, you can log in to your vault by using face or fingerprint instead of entering your master password from this specific device.
Results: You have successfully logged in to the
LastPass app using
