How do I enable passwordless login for my vault?
You can enable passwordless login so you can access your vault using any of the available authentication methods in the LastPass Authenticator app – a push notification + stored biometrics (face or fingerprint), TOTP code, SMS passcode, or a phone call – instead of entering your master password.
Already enabled the LastPass Authenticator app for your vault? Skip to the instructions below.
- Enable passwordless login in Account Settings.
- Enroll your mobile device with passwordless login.
I already have the LastPass Authenticator app enabled for my vault
If you have already enabled the LastPass Authenticator app as your multifactor option to protect your vault, you can enable passwordless login by confirming your master password.
