About excluding passwords from the security score calculation
    You can manually choose which passwords you want to exclude from your security score calculation to prevent your overall security score from being negatively impacted.
    You can exclude passwords from your security score calculation in the Security Dashboard.
    View the "Related Articles" below for instructions.
    Note: Are you a LastPass admin for a LastPass Business account? You can manage the "Control security score calculation" policy and its settings for your end users.
    Note: The security score calculation for federated login users excludes the "Master Password score" since these users do not create a separate master password to log in to LastPass (they use their Identity Provider credentials instead).
