You can export the contents of your LastPass vault so that you can keep a secure copy for your own records. This export method will display your vault data on a web browser page so it can be saved.
- Go to the LastPass login page at https://lastpass.com/?ac=1
- If prompted, enter your master password. If desired, select Do not re-prompt for and use the drop-down menu to select a time interval.
- Select Continue.
Result: An email notification has been sent to your LastPass email address for verification.
- Check your inbox for a "Verify export" message, then click Continue export in the email to verify.
Note: The verification link expires after 10 minutes.
- Return to your vault, then go to again.
- If prompted, enter your master password and click Submit.
You have successfully exported your LastPass vault data, and it is displayed in a web browser page. You can copy the contents and paste it into a text editor to save the file locally.
