How do I force a sync of my LastPass vault data?
    If you are experiencing a sync issue with your LastPass vault, you can force a sync of your stored data by refreshing your vault.
    Additionally, if you encounter an error when performing an action within your vault or want to force recently made changes to be manually synced, you can refresh your vault to push those changes through.
    Note: If your vault appears to be blank after recently upgrading to LastPass Premium, please see I just upgraded my LastPass plan but my vault is blank, what should I do?
    View the "Related Articles" below for instructions.
