How do I force a sync of my vault data using an Android device?
You can manually sync your vault using the LastPass app for Android.
Before you begin: Download the
- Open the LastPass app for Android.
- Log in with your email address and master password.
- Select
in the upper-left of the screen.
- Go to .
Results: Your LastPass vault data has now been synced.
What to do next: Once refreshed, it is recommended that you log out and log back in to LastPass.
